Cooling issues/plugged radiator
- Replies 11
- Views 3.4k
TFaoro 3 posts
Mopar1973Man 2 posts
WiscoRedkneck 2 posts
Hawkez 1 post
Popular Days
This is good information and is the same I've experienced with three different Cummins engines, two that I now own and one I owned in the past. Thanks Dripley as long as your name doesn't come from ha
The only time you ought to hear the fan running is on first strat up or when under heavy load. You will hear run on first start up and some times on a hot start up. Should not run for long, just enoug
Friday after work I was able to examine the radiator and I found the radiator filled debris and what not(used video scope light and mirror). Now later that night at a gathering I ran into an ol
Since I got the truck back on the road abouta year ago I have been fighting cooling problems. FYI the truck sat torn apart for almost 3 years and endured me moving twice during the process.
When I first got it going it started to overheat sitting in the driveway at idle on a 95° day.
I found a bad water pump replaced that and flushed the system. I try to flush the system once a year, after I replaced the pump I was good or so I thought. The truck would sit at 190 and with a large trailer it would creep up but never overheat and it was only at slow speeds. I replaced the clutch in the fan and made an improvement and now when the engine revs up you can here the fan so that was bad for awhile
. Yesterday it climbed well past 190 again
so I let it cool down and pulled the thermostat and still at idle at 90°degrees ambient temperature it still goes past 190 at idle but drops down after I start moving. I'm thinking plugged radiator but I don't know any more... any thoughts?
