Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 75k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
yep crossover remover,  you thread it onto the end and it will hold the crossover tube out.
I saw it threaded onto them but couldn't come up with how I could use it I guess lol... Anyway I did a thing tonight, 0-100 on my daily tune with no wire tap... Couldn't see smoke output but its next to nothing I imagine... Here's a video of my dash and a data log... (all done on closed course....... Of course...lol)
daily0-100.csv
Scratch that.
Edited by jlbayes
daily0-100.csv
Is that a nv4500 or a nv5600?
So the fuel leak seems to have stopped... But here's my current issue after injector install... Hard starts.. If it sits More than 5 minutes it cranks a lot. Then it just fires up, usually. Sometimes after sitting a long time up to 30 seconds of cranking.then it just fires up and runs great. Shut it off and it will fire right back up no issue. I noticed the return tee at the back of the block was damp with fuel I was thinking this could very well be my issue. Nose up it starts really hard, nose down it is kinda hard. But here is the kicker... I feel like the other day my oil level way halfway in between add and full and today it is exactly at full, no signs of water and doesn't smell like fuel so maybe I checked it right after I shut it off or added and forgot I added... Thoughts?
Keep an eye on the oil level. See if it continues to grow and if the oil pressure drops on you.
Mine had the same symptoms u describe and I was chasing it for awhile but. I think it was from me doing a bad valve lash job my first time. It ran fine when warm, basically what u said to a T minus I never put it on a hill. I also wanna say it started better with the drive pressure leak fixed, but I may be getting that and the valves mixed up in my head. I fixed both problems back to back.
Being with all the miles I'm doing I'm going to redo the valve lash my truck soon. Trying to scrape up every bit of efficiency I can get out of my truck. Even change the BHAF today in hopes of just a wee bit less restriction of airflow. Then finding the loose ground on my Quadzilla and the weird issues it created. :doh:
@Mopar1973Man think that is what was causing all your issues with missing and stuff that you and Nick were trying to constantly track down?
I just re did my valve lash. Took my time as double checked it.. They are spot on.. I just replaced the rubber seals in the return tee... Man that is a pisspoor design!
Pretty sure. I found a few valves on the tight side dead cold. I admit I did the lash beforehand but in a rush so I grab a torque wrench and just set my torque on the jamb nuts and threw the cover on which in turn made a few tight in the lash setting. Last time I double checked my gap after torquing.
330k miles and never leaked. :shrug:
Mine have been replaced 2 times under my watch now....
Btw.. #2 still leaking.......
I rly thought I did my valve lash spot on the first time so I never thought it was the problem but after the second go around all of a sudden no hard start.
Where did you get your rubber seals for that T and what did u pay? They are the only thing I haven't replaced... But mine are ok for now. But I need to do em.
For #2 still leaking loosen all blue line clamps and loosen injector hold downs. Loosen line, wiggle injector with a wrench in the top of it as u snug the line good. Tighten injector hold downs. Tighten line rest of the way . Then do the blue line clamps. In all seriousness I bet u already knew that .
Edited by rogerash0
I got mine at Cummins at $10 a piece :sick: I don't see why a guy can't take a piece of fuel hose that size and cut little pieces at right length :shrug:
I'll just leave this here.  Went for a quick spin and the three tunes I built need a good bit of work so no data or videos for now.  More to come hopefully tomorrow.
First time I got them from case ih for about $6 each, tonight I made them from 1/4"fuel line. Worked great
I have tried everything but a new o ring... I had a time getting this one to seal after rebuild as well.. I have a feeling the line is bad.. There is a tiny bit of pitting on the end of the line, I even tried sanding it with 800-1000-1500 sand paper... I have tried about a dozen times or more.. On the look for a line. I think @dieselautopower is sending me new o rings soon.... I hope
Looks good! Looks like a very slight haze??  Mine are about a third the amount of haze compared to my 6x.013"
im only on page 7 as ive just found this thread.  Ive been quiet for a while now.  I have  fuel boss mechanical pump setup i have a quad and a set of dap 7x11 sac. injectors and quad are great. truck starts way smoother and idles quieter.  I have the 6 speed and i have an offidle problem that i nearly have dialed out with the quad. It involves fueling and timing adjustments. i have noticed however that it idles most of the time at 15.5 deg timing. the few times it drops to 11.6 it drives and takes off way smoother and antistall works great.  hpw do i adjust idle timing?  im interested in some testing and whatnot but need help with a dual disk clutch and headstuds for the project.
Sounds like u should make your own thread. I would think a sensor is cranky if your seeing that much variation of timing at idle. I went thru and replaced em all with Wells sensors , made in the USA from AutoZone. Their documentary of their apps sensor on YouTube made me a fan.
I heard the T seals were pricey, that's why I asked. I'm surprised 1/4" line worked.
On the leaky #2, do u torque it to spec or make it tight/hella tight? I am a fan of always using new orings. I'd be curious to hear if they fix your problem. I even bought new connector tubes a second time after having bought new ones originally... And of course they were the same. Ddp originally then bd for cheaper. I had the same problem. Did the same thing, sanding it down. Overall found it critical to snug the line first then do injector then finish snugging.
Edited by rogerash0
I have tried every combination of to spec, a tad over, a lot over, along with different orders of tightening... I didn't change o rings because I have a cr head with custom tubes and the o rings that came with injectors are for vp tubes... But they are also only 5k miles old and I inspected closely and they looked great, then put a dap of oil on before I popped them in....
