Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 89.3k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
Little update, right now I have the tune almost where I want it just a few more tweaks and it should be perfect.
Btw I let off around 70 so not bad all if you ask me.
Power is awesome and sometimes I worry with how quick the power comes in.  I can tell you that I would not want to drive the truck without the quad pulling the canbus back.  Even as it stands with the canbus maxed at 79% I can hit 40-43psi easily which is just about where I want it.  If I was smart i would hook up the gate on my turbo but I just haven't felt the need to bother since I can control overall boost with the quad.
I'm happy with the performance and you would never know that the truck is running a 240hp+ injector from those videos.
So I finally got my fuel leak fixed. All it took was a new(used) fuel line a new o-ring popping the injector out cleaning up that tips on the fuel line and crossover tube multiple times and taking the line off and on and off and on and injector in and out and in and out and trying to find no ring that would work in town. All in all almost 4 hours more work and it appears that the leak has stopped. The truck fire sup almost instantly period quicker than it has ever started before. I don't even know if it makes one fold turn before it fires up now. Uphill downhill cold or warm 0 degrees or 40 degrees doesn't matter it just fires right up.
So now I'm thinking about getting a set of the same injectors set at 305 bar to do some testing and comparing.. Still up in the air I guess right now I have a couple choices. I sent in my old injectors and just found out that they were in fact junk. They were junk out of the box. Don't ever buy injectors from contagious diesel. But anyway I'm at a spot where I can have the same nozzles as I have now set the 305 bar for testing or I can do something like put a 125 horse power nozzle Giver take on those bodies and just sell them to regain some of my lost money. I just don't know what the right thing to do is. What do you guys think?
I wouldn't hook it up. I'd leave it sealed up. I think with proper tuning, wastegates on single turbos are a logical falsehood. I mean if you couldn't control fuel properly based on boost then it's necessary, but with the control we have it's a no brainer.
While a properly sized turbo (compressor, turbine and exhaust housing) will not need a gate anything undersized will. Issa long dark deep worm hole into that side of things.
I really don't like that wormhole.
Idk, I tend to enjoy it when I can get it...
After reading through all of this thread it looks as if quad tuning could really help my truck and help me tune my twins after I get it installed.  I will have to look into making a purchase.
Update.. My #2 line still leaks.. New o-ring, new line swapped tubes loosened injector.. I have tried a million things a million times.. Still f-ing leaks.. Irritated doesn't begin to describe it.. I have spent close to 10hrs total trying too fix this damn thing.. Going to swap #1 and #2 injectors next I guess...
I would replace the #2 injector line. There has to be mating problem with the high pressure.
I have..... No change
I ran a test yesterday comparing my daily tune to a stupidly aggressive tune set at %150 duration from 0 psi to 30 psi.   I wanted to know if there was a significant difference in power between a clean tune and an overfueled tune.
You can see the huge amount of fuel down low.  However most everything else follows each other.    Both reach 60 mph at pretty much the same time, both have about the same egt's and both build and hold boost exactly the same.
The overfueled tune did feel more responsive when not at WOT, but that was simply because I didn't have to push the pedal down as far to get the same seat of the pants results.
2 hours ago, jlbayes said:
Bring it to me and I'll get it to stop.
What's your plan because I can't even think of any thing else or any other combination of things to try at this point.. I have done it million times a million different ways..even swapped injectors.. Stays on #2... I have used different O-rings swapped tubes swapped injectors tried every tightness loosen clamps to clamps off loosened injector tried it with every odd combination here and there in between all of those things. At this point the only thing I can conclude is my number two line and the used number to line that I bought to try to replace it are both bad
I have a polishing method that works great. I fight my ppump 24v lines every time.
I've used 1500 paper and my fingers on the line with good results, just pay attention and be patient. And make sure you give it time to stop leaking as some fuel is left behind the nut that screws in head and with heat from head fuel will come out pass threads, that's why if you don't have hard starts (I don't think my truck makes a full revolution before it fires up) leave it be for few days. Or something is cracked, like tip of the line.
I'm been fighting a surge around 80% throttle. Very noticeable 1st-4th almost feels like the wire tap is coming on but I'm at setting 3. I'm trying to get a good data log of it happening.
