- Replies 12
- Views 3.3k
Dieselfuture 2 posts
Greenlee 2 posts
william keagle 2 posts
dripley 1 post
Check control arm bushings (4WD) a-arm bushings (2WD), ball joints, possibly track bar, brake caliper frame bolts... That should cover most common stuff.
All you replaced was the front brake rotors and pads. You also replaced the left front wheel bearings, inner and outer. You didn't have that clunk before you did this job? So it must be some thing
just got done changing front brake rotor and pads. why'll doing it found the driverside wheel bearing was bad. strange to me because the truck always wanted go to right? but anyway back to the problem. the first time i hit the brakes why'll moving forward there is a clunk sound coming from the front end. but does not do it again inless i go backwards and the first time i press the brake it does it again. but no more until i go forward and hit the brakes again. any ideas on this? and yes i tightened everything to the proper torgue spec.
Edited by william keagle
