Quadzilla Warmup / High Idle
- Replies 28
- Views 22.3k
Mopar1973Man 7 posts
Me78569 5 posts
kzimmer 5 posts
Quadzilla Power 4 posts
Yes and no. 3 CYL cannot be held. It will self-cancel after coolant reaches 170 or so. 6 CYL can be held if the selector is left in the 6 CYL position. If you start the mode a
I actually don't mind it, i used it few times to back up at a steady speed lol. And once I was on some sleek dirt going up hill, so I put it in 1st 4x4 low and high idle on and walked beside the truck
Due to the size of the injectors I can't say if it is not normal. It takes a good bit more fuel on a cold motor to get RPMS up. as the motor comes up to temp somewhat then it takes less fuel and rpm
Hey guys,
I have warm up mode and high idle activated with a 90 second delay, until 140°F ECT. I want to verify intended functionality. Here's how mine works.
After the 90 second delay, my tach jumps up to about 950 ish. After about 10 minutes, they smoothly increase to about 1200. Does this sound normal? I'm not sure if the two-stage RPM is intended or not. I would kind of prefer to see 1200 RPM instantly when it's cold out.
-Kole
