- Replies 35
- Views 5.1k
903Dodge 9 posts
Mopar1973Man 7 posts
DieselJunkie 5 posts
Dieselfuture 4 posts
Check the thermostat housing as well. I've seen them start oozing from a bad thermostat seal as well.
Just did mine with head off, took like 10 minutes, took longer to clean things. There is a bolt behind vp but you'll have just enough room to do it. But I don't have a factory fuel filter housing in t
Was that maybe just for common rail trucks?
Like the title says. I noticed this coolant right below the exhaust manifold.
Any ideas if it could be a Head gaskets issue?
Just changed the oil and it's not milky. The coolant still looks good.
