- Replies 20
- Views 5.7k
Cronus577 7 posts
Dieselfuture 4 posts
dripley 3 posts
015point9 2 posts
Pretty sure it doesn't come with anything. At least both trucks I've had didn't have one. If you're going to remove them, I'd recommend grinding down the corners of the forward most one so you don't h
I have only pulled mine twice too. Once on the first day of my AD install and once the next day when I realized I did not install a couple spring clamps completely.
@Dieselfuture yeah the felpro is the top and it sealed perfectly. The Cummins one is the one on the bottom. The white part is dust seal, It was straight but I tried to push it in a little to see if it
Is there supposed to be any type of padding or protection between the metal strap that holds fuel tank in place and the fuel tank?
Front strap is held in place by a metal bracket that strap goes into. Metal bracket is bent …trying to figure out if it was bent on purpose, to prevent strap from falling off…just in case strap ever came loose or is bracket bent from road debris?
Figure 14-110 in parts manual doesn’t show anything between strap and tank , but maybe some type of protection a good idea?
(My old Ford had something like gunny sack material between tank and strap. I replaced with a rubber inter-tube. But tank was from late 80's with alum tank, if I recall right)
Edited by 015point9
