- Replies 25
- Views 7.5k
Cronus577 11 posts
Mopar1973Man 4 posts
JAG1 3 posts
notlimah 2 posts
Popular Days
Best to find a vented cap so it has the one way check valve built in for safety. My redneck way of drilling the cap is you only drill a 1/8 inch hole thru the first layer on the underside
Always good to hear of a problem solved. Simple or not so simple.
Haha I know all too well of being wrong all the time. On the last 2 hours of the drive and she feels great. I'm at 16,210lbs gvw and these compounds keep me right at 900-1000f for my EGTs pulling a 6%
Just finished an 8 hour drive and I'm noticing my truck is lacking power at operating temperature, used to have no issues with taking off in 2nd when I had a FASS DDRP and stock injectors but now it struggles taking off in first while at operating temps. *My fuel pressure at idle used to be around 9-10 at WOT it would drop to 0. This was when I first got the truck and knew nothing about it a few years ago now I have a FASS 150 with a sump and the gauge sits at 15psi and 14psi under WOT*. But I ran it like that for a couple of months just thinking above 0 was good enough. Fast forward to knowing what I know now, I'm pretty certain that I've damaged it and now I've got a weak VP44 but I don't have any codes or a CEL. All mods are in my signature, my iQuad shows my timing is moving properly as far as I know, it doesn't seem stuck or anything, no hard start issues. Thoughts? Replace it or just send it?
On another note, the sluggish take offs could be map sensor related, but I see full sweep of 0 to 57 on the iquad while getting up to operating temps with plenty of power and my ISSPRO gauge can verify but when it's fully warmed up I get about 0 to 45 on the map sensor while the ISSPRO will still read 50+
Edited by Cronus577
