- Replies 54
- Views 22.5k
Curt026 26 posts
dripley 11 posts
Mopar1973Man 7 posts
trreed 2 posts
Pins #3 and #9 are not used by the injection pump that is why there are no female terminals for those pins in the connector. If you pull back the rubber covering to the connector you'll find no wires
I mean I'm literally replacing all the negative battery connections. The drivers side was able to be wiggled back and forth and and pulled off. It's not hard to damage the stock clamps especially afte
IM surprised it hasn't been asked already, and for that matter the lack of response in general, but I just checked the ac voltage. Measured at alternator post and grounded to alternator I have 085.9 m
Hey guys first time poster over here. I was fairly active on cumminsforum years ago, but then life got in the way. I've owned my 2002 2500 for about 8+ years now and it has just over 111,000 miles. I had a company vehicle until I switched jobs in June of this year and now I'm dependant on my truck. Long story short is last week on my drive home it just shut off on me like someone flipped a switch. It took a couple times cycling the key back and forth until it would start because I quickly realized that the lift pump was not priming and it wouldn't start. Well it did the the rest of my drive back home (about 5 more times) and has been parked ever since. To be clear once it stalls it will not start until I cycle the key or wait a few seconds and then when I turn the key to on and hear the pump prime it fires right away. It's throwing 1689 and 0341. I finally had a chance to play with it again today after reading up on the issues over the past few days and have found a few more things out. Most importantly is that when I cycle the key off and back on the wait to start light does not light up and the pump doesn't prime. Then when it decides to work I see the wts light and hear it kick on the lift pump and she fires off. I hope this is making sense. I do have an old school quadzilla v2 from before they went out of business and every so often it would freeze up on me. Literally two weeks ago I thought I had that issue diagnosed with a possible low voltage symptom. The gauge in the truck is basically useless and I did not realize that my truck is only charging at 13-13.4. So could there be a correlation here between the pcm and ecm? I'd rather just wire in a regulator at this point but I need to do what I need to do. I'm getting ready to change out the negative cables and all the grounds that feed off the battery because I changed the positives a year ago because of bad clamps. Does anyone have any advice on where to look first or save me the trouble and just confirm it's the ecm? I've done no testing yet for the two codes it's thrown. I appreciate any and all advice and I hope some of this makes sense
