- Replies 12
- Views 2.5k
CUMMINSDIESELPWR 5 posts
Dieselfuture 1 post
01cummins4ever 1 post
Silverdodge 1 post
yassa hahahaa, just put the leads to the battery posts, i have a switch built onto the existing relay harness, shove the clear tubes into the dipstick tube and the outlet into the 5gal bucket... fli
This is hilarious, I used my old unreliable raptor to pump water into my garden hahahha. suppose they are good for something.
i just take the 5 gal bucket and pour into the recycle bin at the parts store. it should be able to run backwards.
so i finally found a use for my old electric lift pump. using it as an oil extractor for oil changes. works like a champ, tested it on the bmw. got all of it out (6.5qts) in about 5 minutes. so no more back breaking “get under things” to change oil.
