- Replies 124
- Views 20.3k
Marcus2000monster 52 posts
Mopar1973Man 26 posts
kzimmer 7 posts
trreed 7 posts
Use two pair of needle nose vice grips with vacuum hose pushed over their jaws to clamp fuel hose and adjust to fit hose. I've used this setup on heater, fuel, brake and transmission hoses with no p
yea you are idling WAY to long. I typically give her 30 seconds on a close start to stablize oil pressure and rpms at idle before I take off. all you are doing is burning fuel.
My belief is if the truck knows you like it, then it will break because it rules the roost. If the truck thinks you dont care about it then it will work fine.
So ever since I had the drop in fuel pressure which I have not mechanically tested yet my fuel economy has steadily went down since then. Have not had the chance to hand calculate yet but lie o meter says it went from 16.8 to 14.3. I picked up a tester today so I’ll be able to rest idle pressure soon. Where do I hook up the tester?
The pressure went went down and then back up to 17 18 at idle and 12 13 wot.
Used to be 19 20 at idle and 15 16 wot before the drop.
