- Replies 12
- Views 2.2k
Popular Days
Yes. The panel is brittle, best to pry a little and cut the little clips. Pry too much and the panel can break before the retainers/clips pull out. clipsandfasteners.com has them
If it's just the switch ..... it's an easy repair. Pop the window/lock pod out of the door. Easy to do with a small screwdriver. Un-plug and remove the switch. Gently remove the flat panel on the
Power door locks
My pass side stopped unlocking a couple years ago. It would lock,down. but not unlock,up just makes a noise, eeeegh
I have never took the door panel off and to check it out.
Then I saw power door lock mechanisms at Geno's for about $200 ,,,geeze !
So has any one repaired a power door lock or do they just phuck up and need replacing like all the other new modern electronic crap?
Edited by GSP7
