4x4 won’t work! Help
- Replies 58
- Views 11.2k
Marcus2000monster 23 posts
Mopar1973Man 12 posts
dripley 8 posts
Me78569 3 posts
I know I am posting this a little bit late, but I wanted to clarify some things. I also apologize for any confusion on my part as to whether you should use the hand-operated vacuum pump or use the en
I will vouch for the 4x4 posi-lok as well. I no longer worry about my actuator failing on my 98.5 at the worst time and the 2WD low is great for backing trailers.
A hand operated vacuum test pump is a good investment, is not that expensive, and will allow you to accurately diagnose vacuum related problems. For example, the CAD unit can easily be te
Ok guys I honestly hate to start another thread but I have a serious problem. It is the dead of winter and my 4x4 won’t work! The engagement stick moves into place but no dash light or 4 wheel drive! I need to get this fixed ASAP! I used it last week so it worked fine then. Help?
