2001 24v auto 47re
truck seems to not want to shift into overdrive untill 55+ mph at light throttle. Wondering what other people experience with their trucks. I have 36" tires and 3.55 gears but my speedo is only 2mph fast verified with gps. It will shift most times at 57mph on the speedo and 55mph shown on my scanner reading the VSS.
From what I've researched overdrive is controlled by PCM once the apps, trans temp, output speed sensor parameters have been verified and not by the adjustment of the tv cable or fluid pressure. (Could be wrong). I drove with the scanner hooked up and verified the overdrive shift happens when voltage drops to the 3-4 shift solenoid at 55mph so it's working as designed. Is there a way to lower the overdrive shift speed? Even with the tall tires and tall gears it seems I'm always driving around town in 3rd gear locked around 2k rpm. I can get it to shift into 4th by letting off the throttle quickly above 40 mph but that gets annoying. I've searched and searched for days but didn't really come up with a solution.
  • Replies 41
  • Views 15.8k
  • trans output shaft
  • We dont get trans tuning, nor will we have it ever, as that is part of the PCM and not the ECM for us.  The PCM will never be open to tuning lol.  I am guessing the early cr trucks use a PCM as well,
  • More coffee. It looked like you were responding to his post this morning.    Yeah 27° seems like a lot for no studs, but that is at 3K rpms where it's needed and start of ignition won't be a
When you let off the throttle you’re getting below the threshold of TPS for that TOS, so it shifts.
Yes load increases for a given TPS, which generally means that you use less TPS for the same acceleration. Lower TPS means a sooner 3-4 shift.
While I can’t see the tables for earlier than 04.5 your transmission is doing exactly i what would expect for your current tuning and tire combo.
Is there anything in quad that lets you adjust the fuel at a given TPS?
2 minutes ago, Me78569 said:
Your large tires are creating excess load resulting in heavier throttle, which results in more TPS to move down the road and later shift points.
Making your tune more aggressive will help, but it is a bandaid fix rather than a solution.
I agree on the tires and the standard TPS table, but I’m not sure it’s a bandaid... at least with current tuning options. If the pre 04.5 trucks ever get trans tuning then it could be a real fix, but until then adjusting fuel:TPS is as good as it will likely get from a tuning standpoint. Mechanically 4:10’s would do wonders :-)
We dont get trans tuning, nor will we have it ever, as that is part of the PCM and not the ECM for us.  The PCM will never be open to tuning lol.  I am guessing the early cr trucks use a PCM as well, which is why there is no trans tuning for them either.
The quadzilla will indirectly allow this shift to happen sooner if you increasing your fueling % in that boost range.  Increasing the % of fueling at a given PSI will make it so you need less tps movement to move down the road at the same conditions as before.   IE if you are at cruise at 3 psi and you increase your 3 psi fueling % by 2-5% then you will notice earlier shifts during those conditions.
This will however result in overfueling in some situtations.   My guess is you wil fix the shifting issue and break something else.  It might be worth it, it might not.
You could also try bigger injectors, that iwll have the same effect as increasing your fueling via tuning.
Edited by Me78569
22 minutes ago, Me78569 said:
 What is the tune you are running on the Quadzilla,  that will indirectly effect when the trans shifts based on how much TPS input you are moving at a given condition.
This is my tune parameters. I have a HX35 4" straight pipe, k&n cold air on it currently. I just got DAP 7x0010 SAC injectors I'm just waiting on time to put in.
make your 3k timing settings 27* and your max 30*
You cna try adding %5-%10 across the board, that should solve the shift issue, but you are really limiting the resolution of your throttle pedal.
Will the 27 degrees be safe without studs? I don't get up that high in rpm much anyways because of the stock trans. Correct me if I'm wrong but I believe I have max fuel @ 10psi now? My problem is the 3-4 shift doesn't happen untill 57mph when just putting around barely touching the throttle. From memory watching the gauges at 70mph highway I only see 20-25% tps and 30-35% load. I haven't driven the truck today to check so I figure at 50mph when I'm waiting for the shift to happen it's more around 15-20% tps. It shifts good getting on it. It's when I'm barely touching the throttle it won't shift 3-4.
I turned the fueling up to max across the board. It's shifting @ 48-50mph. Seems to have worked. Thank you guys for the help. Hopefully this helps someone searching.
Most likely going create a loss. (Negative torque) with that high of timing. Not being able to see your signature and what you've got for truck makes it hard to tell. I'm going to suggestyou see what @Me78569 has to say being he's the Quadzilla guru.
He turned up the fuel, not the timing.
He asking if you can reach 27 at 3K and 30* MAX timing. Not knowing the engine setup I'm not sure it would be a safe setup.
Every truck on the road with and edge or a old quadzilla was maxing out timing by 3k rpm, sometimes sooner.
Yeah 27° seems like a lot for no studs, but that is at 3K rpms where it's needed and start of ignition won't be anywhere near that high.
Edited by AH64ID
You can't see my mods? I filled out the signature thing. How do I fix that?
I personally can't. Can you see them at the bottom of your posts?
  • 6 months later...
This was a good read.I have the same exact issue with my 98 12 valve/47re.
I was thinking With bigger injectors I could
fix the problem. I figured there is to much throttle valve tension but with more fueling
it would fix my issue.
I tried adjusting my TV cable and if I remember right it helped on the lowering my 3-4 shift speed but it also made my 1-2, 2-3 shift to low as well.
I heard you can mess the trany up that way so I put it back to where it was and I just let off the throttle at 57mph to get it to shift into forth but it's annoying.
My tires are 285/70/17's.
Was going to check my tp sensor as well.
I wonder if uping the line pressure would help as well? That way you wouldn't have to give it as much throttle to make it shift maybe? I don't think the 47RE is as bad as it's made out to be. Just needs to be set up right.
Edited by BIG-BLACK-DODGE
Best suggestion is get ahold of @Dynamic he would know about the set up for your condition.
Cool thanks. After I posted I read up on the 47RE line pressure. You can up the line pressure simply by turning a screw out under the pan. Need to be careful on an older trans because old seals may not be able to take the pressure.
Also there is some very interesting info on what type of ATF to use. ATF+4 is said by many to be to slippery. Dextron 3 is supposed to be better. And if not in cold climates some use hydraulic fluid that is like a " shift kit in a bottle". Lol
I actually switched mine to DEX3 a while back and it seems fine you need to pump out the old fluid because the fluids don't mix well.
Again talk to @Dynamic about the fluid and the requirements of the mods before doing a fluid type change.
I read up on it quite a bit before I changed mine. I had an F-150 when I was younger that ran Dex3 and that truck went through hell! Lol 405,000km's when I sold it on original trans and it shifted like the day I bought it.
I Tow 12,000 lb toy hauler and my oil is still nice and clean however I would need further testing to give an honest opinion.
When Georend trans builder guy says to use it that's convincing enough for me.
Is that who "Dynamic" is maybe?
Hopefully Dynamic chimes in.
