Purpose of lockup switch
- Replies 54
- Views 21.4k
notlimah 12 posts
JAG1 10 posts
AH64ID 8 posts
Tractorman 8 posts
You have now read several posts for different scenarios for having the torque converter locked up, and they are good posts. But, the really important reason hasn't been mentioned... and that is heat
My 6 spd manual transmission locks up in every gear, even reverse! However, it is very annoying the way you have to unlock it - you can't just flip a switch. If you don't unlock it during shifts, it
I love it when I'm towing my 5er. I've been using my switch set up since April 28, 2015 All the time If you were towing with a 5 or 6 speed transmission you wouldn't b
I’ve been trying to do some research of what the purpose of a lock up switch is but can’t find a clear answer. I get that it’s used to lock up the convertor but what I can’t find a clear answer on is under what scenarios would you want to use a lock up switch? I know this is a newbie question but I just don’t know the answer to it ?
