Possible ground and tq problems
- Replies 16
- Views 3k
Mopar1973Man 3 posts
Dieselfuture 3 posts
Jnhobson95 3 posts
dripley 2 posts
No problem I have no idea haha, but I was just thinking when his truck runs it would be good idea to check for it. I suppose he can bench test it too. When gauges and electronics along with tc hunt do
Was the alternator in your hand or still on the truck for the alternator test? If still on the truck, it would not be a ground problem. Something was drawing current. .... freaking gas
I’d scan for codes, sounds like something in the trans isn’t happy.
Been having problems for awhile with my torque converter not locking in. Took it the shop and they put a new torque converter and selenoids in the valve body. Started working but now it’s having the same problem. Also the voltage gauge has now started staying at zero and won’t crank. Every once in awhile it will crank and after you drive around for a few minutes the gauge will go back to zero. Checked all the grounds off the batteries and they seem fine. Any help appreciated.
