Missing, random codes, occasional stumble at idle
- Replies 20
- Views 4.1k
Dodgeih 11 posts
Mopar1973Man 3 posts
dripley 2 posts
Dieselfuture 1 post
About 3 weeks ago I started to get a check engine light with a cam position sensor code, that I cannot remember the number of, a speed sensor code p0500 and a p1693. It would come up after a hard pull. I let off the throttle the tack would drop and the check engine light to come on. It continued to get worse. It also had a random miss or stumble at idle. It was very audible through the exhaust and it would just do it every once in awhile and is kind of hard to explain. Just a random blip through the exhaust. Then one night my grid heater started pulling down so hard that it would kill my headlights and dash lights. They were kicking on and off randomly off time and pulling so hard that it even killed the truck couple times. Then randomly the truck over charged and pegged the gauge out at 18 volts. Luckily this happened when I was on my way to town to change the cam sensor anyway. I got that changed out and all the symptoms disappeared. I'm about 3 days later I did another hard Pull in this time it completely cut out around 2500 rpm multiple times. Attack would drop no check engine light and it did it on any setting on my quad. Even with the quad turned off on stock settings it did it. Also the blip or miss at idle is back. It had gone away a few days after cam sensor replacement... Truck actually ran better than ever right after I replaced that...I am kind of at a loss and I just and idea stuck in my head that it's something like the ECM or vp44 even though my wait to start light kicks on right away. Any ideas would be appreciated I will attach a data log from when the truck was cutting out on hard acceleration. There should be two separate pulls one on setting 3 one on setting zero sorry for any typo..voice to speech isn't the best thing in the world sorry if the data logs overlap. I do not have a way to make these into a graph sorry
stockmiss.csv
missing.csv
I also forgot to mention that for about the last 2 or 3 weeks it has also randomly started and shut right back off about 5 times only one really cold. It has done this maybe three or four times total but each time that it does it the engine fire sup and dies about 5 times
Edited by Dodgeih
