Engine rebuild
So, I got my first quote back for rebuild....erf...gut punch...Anyone have a recommendation in Minnesota for a rebuild?  The first one back from the local Cummins rebuild is $12k+....or is that about right?  Budgets need to know...
Sorry in advance if this has already been discussed and I could not find it in a search.
Edited by PilotHouse2500
  • Replies 30
  • Views 10.2k
  • Dieselfuture
    Dieselfuture
    I personally would not take anything to to Cummins,  especially the ones around where I am at. It seems that they hired all the retards out there. The price is ridiculously high, if you can put the mo
  • Pilot, whatever stand you buy...use the side of the engine to mount it (engine mount bolt boss'). Do not use the bell housing. Much more stable that way.
  • Thought of this thread after seeing this in Golden, CO
I saw that truck yesterday on my way out of Denver, sets at a shop right off  I 70. late 40’s  Ford it looks like,
I wonder if it’s got a Cummins
It's a late 40's early 50's Ford(:spank: my brain fart!)with I believe a little CAT and an Allison. It also has rear steer and can side walk taking up two lanes. I'm hoping to get a close look at it parked somewhere during a cruise weekend in Golden.
Edited by BBHD
Brain fart!
Y’all are talking about the one at 5R Trucks huh.
Beauty of a truck, looks like 2.5 ton axles too. Easy to make all wheel steer.
It has it :thumbup2:
  • 9 months later...
I found when we built the engine in my bride's dually that the gasket kit from Cummins was the most expensive part.  ($1,000-ish iirc)
the bearings and hard parts were super reasonable.
If you have mechanical ability, I would recommend building it yourself.  They are basic and stout.
And building an engine is fun and super rewarding when you are towing your load over a hill and passing cars like you are empty...….
