White smoke on start up less with warm motor
- Replies 44
- Views 6.8k
Unreal Summit 21 posts
Marcus2000monster 9 posts
Mopar1973Man 6 posts
dripley 4 posts
Popular Days
That's a good idea with the fuel pressure gauge. I need to just bite the bullet on it.
I don't know what additive you used but I would highly recommend using some 2 cycle oil. I use super tech from wall world. It is good for the entire fuel sytem especially the VP. Today's diesel is not
Here is an article about it. One oz per gallon is the desired mix but dont worry if you put to much or dont have enough at a fill up. Any is better than none. Just try and keep it close. TCW3 is
I have a 2002 2500 5.9 that when started on a cold morning blows white smoke for a min then stops. When I stop some Where and get back in and start up it puffs white for a second. No loss of power no CLE no soft codes. Not sure of fuel pressure. I know I need a gauge. My question is is this somwthin I need to worry about or no? I just started seeing it the last few days. But the temp has been colder the last few days. Thanks for any and all help!
