1999 2500 just shut down
- Replies 15
- Views 4.1k
Mopar1973Man 3 posts
weaselguys 3 posts
kzimmer 2 posts
trreed 2 posts
I may or may not be guilty of doing that exact same thing.
So many questions so little time, haha. I dislike the boost elbow. I'm not sure if they're all the same but I want to say I've seen two types. One that simply restricts flow by making the
I just bought one for $5.46. Cheap Thanks
I have a 1999 2500 with manual trans and I added a Quadzilla XZT with a tune that has a high idle on it .I was coming home from work one afternoon and turned off the highway onto a residential street and my rear tires hit a icy patch and started to spin , the rpm's came up and it felt like the high idle kicked in and the truck tried to take off on me , so I pushed in the clutch to stop it and the truck just shut down. I coasted it onto another street and stopped and tried to restart and it wouldn't so I let it set for a few minutes and then it fired right back up . Is there a rev limiter that can shut the truck down or a relay that can trip causing it to not restart and should I do away with the tune on the XZT with the high idle ?
