Titanium 150 Pressure Adjustment
Is there a way to lower the psi on a Fass 150? I have 20 psi at idle and 18.5 WOT and would like to see 15 wot and 17 18 at idle. Iv heard of a different pressure spring? Link? Thanks
  • Replies 49
  • Views 8.5k
  • Yea can't complain. I didn't mind it before but at least it's still within the limits. I am going to be changing filters here soon and also routing my fuel lines back through the stock fuel basket to
  • tylertrebilcock
    tylertrebilcock
    those sound like decent numbers 20 is about as high as you can go with the vp. you could try removing the spring and clipping off a coil or two
  • Marcus2000monster
    Marcus2000monster
    No no i didn’t even put 1k on them lol. I bought it used and he had the 20k on hem lol. My Fass sounds like a rock tumbler and supposedly new filters will make it run smooth like it should haha.
12 minutes ago, notlimah said:
If I were you I'd just look at getting a whole new module from Vulcan before I ran a sump. Just food for thought.
Ordered one a couple hrs ago.
Cool, let us know how it goes.
Alright guys here’s what’s up! Canceled the order of the new fuel basket because I figured out a “better” way to do it! I cut the Draw Straw tonshort while trying to install yesterday. So here’s the deal: He Straw is sti long enough that I can drill a hole beside the basket and the tank vent hose and be able to use the rubber gasket from the stock pickup fitting to install the straw in that location. (Location pictured below) Pickup and return tunes will be plumbers in just like they normally would. Next I plan to add an inline 50 micron fuel filter.  Then I plan to JB Weld a piece of plastic or some other material over the old hole in the top of the basket.  This will be saving me the 357.80$ that I spent on the new basket with drawstraw. Who cares if it’s red neck cuase no one will be able to see it lol!
Is that enough room to get the basket retaining nut in there beside the head of the draw straw?
Thanks for pointing that out. It is very tight but I believe I can make it work. If it won’t work righ there I can make it work just in front of where my finger is on the pic.
If the hole isn't drilled already i'd put the basket nut back on and put the head of the draw straw down to see where it fits best.
Exactly what I did.
Hole you drilled in basket, I think I would use like a 3/8 stainless bolt with two big Fender washers and a chunk of viton rubber something that holds up to diesel, with nylon nut so it don't come loose. I think it be stronger than J-B Weld in that big of a hole
Great idea! Thanks a lot! And that hole is from the stock fitting I didn’t drill that one just FYI.... :whistle:
You're welcome, well you get the idea
Well I’m a bit skeptical but here’s my progress! It’s very tight in there but hopefully with all the rtv I put on there it will be a air tight effective fuel system. If not we’ll ill have to plug that hole and get another straw..... :think:
11 minutes ago, Mopar1973Man said:
Now you need a return for the stock return line. :whistle:  Or are you just dumping the VP44 return fuel on the ground? :think:
He stock return is hooked to the Draw straw. You just can’t see nothin in the picture lol.
Curious about the inline filter. Does the WS on the FASS not serve as a prefilter for the pump?
Some places recommend a 100 micron pre-filter to catch big crap out of dirty tanks to preserve the WS longer.  It’s not really necessary or worth it.
Edited by trreed
This.
I had one of those on my old stand alone Fass 95gpm pumps.
You don't need it with the filtered Fass setup. I don't know how many diesel bath's I took changing that out. And that was with bald jaw vise grips on each side clamping down.
It's  just a screen filter.
I wouldn’t worry about the seal job you did on top of the fuel basket. Even if it leaked it wouldn’t have an affect on your fuel system. You’re just concerned with the actual suction lines themselves being solid. :thumb1:
Thanks! There won’t be any leaks with the amount of rtv I used lol.
Oops too late now unless I get a new length of hose....
Ought to have the truck ready to roll by tomorrow afternoon! Changing the oil to my summer 15W 40 from 5W 40 while I’m working on it. Fass filters and stock filters being replaced as welll.
6 hours ago, Mopar1973Man said:
Here is the AirDog water separator. Just a smaller scale of the FASS. Fine steel mesh. I typically just rinse it out and reuse till rust is visible.
Image result for mopar1973man fuel filter
Mine is the same way.
They do make a pushlock coupling to join 2 pieces of hose together.
