Everyone post a picture of your truck!
Alright guys I wanna see pics of
everyones truck! Post em up boys! I’ll start...
Here’s the truck I almost bought before my truck. 91 12 valve 5 speed with 236k on the clock.
  • Replies 597
  • Views 129.1k
  • woodtrucker
    woodtrucker
    Just upgraded to 17" rims this week. Really happy with the overall look. A lot of work the last year on this truck.  New paint, New Dash, New Tires, New Wheels.
  • 01cummins4ever
    01cummins4ever
    I’m not sure mine fits in with all the clean looking one around here, 305k on the clock. Owned it since 2002. It had 15k on it when I got it.  Just my little work horse
14 hours ago, Evan said:
Nice truck! Those Military wheels & tires are a heavy combo and I don't see any weights? You must be running beads inside?
No beads yet. Theres weights on the inside i left them as they were.
I broke the 5th one down removed the runflat was unsuccessful in re seating the bead.
Im currently looking for a chunk of 16" pipe so I can make inserts to replace the run flats and still be true double bead locks.
Losing the run flats drops the weight about 32 lbs.
I ran those tires for years on some 16.5 American Mags and always mounted them myself. I found the best method to seat the beads was this;
With the tire loose on the wheel, put the wheel on a bucket or small steel drum to get the tire off the ground and hanging from the wheel. You need a clamp/screw on tire chuck so you can operate the air with one hand and a 16" bicycle tire tube with just enough air in it to make it round and about 2"-3" in diameter depending on the gap between the tire bead and rim. Lube the inner tube well with silicone spray and put it over the wheel and fill the gap between the bead and the wheel with the inner tube. It is a bit difficult to get the tube stem pointed away from the wheel but you will use the stem to pull the tube out when it's pinching between the tire bead and wheel. With the gap filled, slowly air the tire and watch the side wall come up along with the inner tube. As the inner tube gets pinched, you need to keep giving the air at full blast as you pull the tube out. You may need pliers to pull the valve stem hard enough to get it out. It may take a few tries because sometimes as you pull the tube out, you loose enough air for the sidewall to collapse again. I've used the same tube multiple times but occasionally it gets pinched enough that the tube rips a bit but I've always gotten it out eventually due to the silicone spray. Works more consistently than a Cheetah Blaster because the sidewalls can be really stiff and the tires have usually been sitting in the backing sun on their sides with a bunch of tires stacked on top of them. I don't know if this will work with the split rims but it might.
Edited by Eric H.
  • 5 weeks later...
Late night rescue mission
Edited by Evan
  • Popular Post
Just unloaded the camper at Newberry National Volcanic Monument south of Bend, Oregon last summer.
  • 6 months later...
You got it backwards -- The KW should be on the trailer behind the Ram :wink:
I dont like towing more than that skidsteer thats in the kenworth. Lol kenworth empty is 22k
Here are both of mine. Headed to a sled pull this previous Friday and Saturday. Got 3rd and 4th respectively in my work stock class.
On 9/25/2021 at 12:55 AM, Brandon39 said:
You carry plenty of spares.
:lmao:yea I probably should have taken the old tires put before the pic
Nice truck.  Reminds me of mine.
