Driving home from work engine the tone changed and my max speed was 60 mph so checked for codes no codes, I disconnected the TS MVP no change, I check fuel pressure seemed normal to me bump key 17psi, running 15psi, mash the pedal to the floor 10psi, my fass pump is 12 years old. Truck is smoking white smoke. I'm thinking it the VP44 it have been in for 10yrs and 200,000 miles. It did this the first time the VP44 died, except it would only idle no matter what position the gas pedal was in.
I'm thinking it's the VP44 again just wanted a second a pinion.
I plan on replacing the VP and the fass pump.
Thanks
  • Replies 45
  • Views 7.6k
  • I never get to say this... Your truck went full retard. Lol. Sorry.
  • No.  Quad shows commanded timing.  That's the unfortunate thing with our goofy electronic/mechanical injection system.  We can't see actual injection timing or duration (two variables that would let u
  • That area must be haunted!  There's a cemetery on a mountain back road (basically forestry road) that every time I drove by it, the truck shut off in the same place. Did it when three different people
On 4/3/2018 at 8:02 PM, trreed said:
That area must be haunted!  There's a cemetery on a mountain back road (basically forestry road) that every time I drove by it, the truck shut off in the same place. Did it when three different people were with me. I don't drive by there anymore.
A different mountain back road, I had a similar thing happen with the white smoke and retarded timing. On a brand new VP at 2.30 am :(
Whenever I visit Colorado remind me not to go on a ride along.
Y'all got me to thinking so I pulled my scanner out and checked for codes instead of using the key and I do have PO216.
Thanks for y'alls help!
Right here is why I ALWAYS suggest using OBDII scanner instead of the key trick.
I assume obdlink is good enough to read these types of codes, because that's what I have and I have zero codes thank God
Goes back to the whole problem...
1998.5 to 1999 do not report any error codes.
2000 to 2001 typically only report PCM codes.
2002 is the only year that reports both PCM and ECM.
So why bother with a key trick system if only 1 year works... Just easier if everyone uses a code reader.
I have a few questions about installing the injection pump.
Do I leave the gear puller attached to the gear till I get the new injection pump back in the case?
When I stick the new injection pump in aligned with the gear key way will the key slide in far enough for the key to be in the key way slot before I start to tighten the bolt?
Or do I need to watch the key and the gear key way slot as I go thru each torque sequence to make sure it goes in properly?
Thanks
No. Not required. All the puller is used for to pop the shaft out of the gear after that it can be removed.
Typically I slide the shaft in and check with a mirror to make sure the key is lined up with the gear before tightening any nuts. Typically I will do the 4 mounting nuts first to draw it in the rest of the way and double check one more time with a mirror for the key alignment before placing the lock washer and nut on the shaft.
Thank you!
Hmmm? Above Central City by chance @trreed?
@BBHD, yes!  Bald Mountain Lane.  Just west of Nevadaville.
Edited by trreed
It must be some poor pissed of Ford owner turning over in his grave because your Cummins is still running.
Considering most of these graves are mid 1800's gold rush miners...... If they had Fords back then I'd be impressed!
2 minutes ago, Dieselfuture said:
Could be something to do with magnetism from Earth like ac noise
Aww my day-time ghost stories aren't working????
It's only ever happened after nightfall.  During the daytime I've never had an issue.  And it gets kinda chilly when you roll by it....  I'm not overly superstitious, but there are a handful of things I've experienced that I can't explain.
The injection pump is out. Waiting on the new one to arrive any tips for the install or priming the new injection pump?
Thanks
I super glue all my keys in to prevent them from falling out.  Then just line up the keyway and its reverse steps for taking it out.  For priming, bump the starter three or four times to ensure fuel has filled the VP, and then crank it to bleed the high pressure side.
I usually have to crack open 3 injector lines to bleed it completely. Occasionally not though.
The last few times I've never bother to even crack any high-pressure lines open. Just cranked for about 20 seconds and it would start. I would bump the starter crack the fuel supply line till fuel was present at the VP44. Jump in the truck and just fire it up. Mine like I said, is about 20 seconds of solid cranking it fires right up.
Book says don't crank over 30 sec then give starter a rest.
 Mine...half inch lines completely empty took 3 times to fire off and didn't crack any other lines.
Just goes to show there is more than one way to skin a chicken.
Cluckity cluck, ya'll.
c
