I just got rid of my boost elbow and installed a manual boost controller recommended by @kzimmer.   It's the best $5.46 I ever spent on this truck.
Now when I mash down on the go peddle the boost gauge jumps to 26psi, trans shifts up and boost goes to 28psi.  When it shifts to 4th, boost hits 30psi and speedo saying 80.
No more boost bleed off.
5ac922a49e511_Screenshot_20180320-171911.png.8a1f0e3619603bfc3f478aa3844a640f1.png.2f98364cb98ee68c558ecc55792b7c9a.png
There is a lot more room on the adjustment for more boost so how much more boost can I dial in and still be safe?
  • Replies 93
  • Views 17.9k
  • This is the link.  The part comes out of Hong Kong.  When I ordered it the delivery date was posted to be 3 to 6 weeks, it came in a week.       https://m.ebay.ca/itm/Adjustable-Manual-Boost
  • I mean....if you are handy with a drill and a tap anything is possible....
  • A pair of tin snips mitigates this problem... Ask me how I know, haha.   Don't cut the spring. If you are looking for more boost, assuming you have enough fuel and don't have any boost lea
Just now, Dieselfuture said:
Not till you get the quad, but you may want to order one now as it's going to take a month for the better to arrive
I do have a boost fooler donut should work fine right? Obviously it ships from China?
I did not know you had a boost fooler, in my understanding you can adjust your wastegate all you want with adjustable boost elbows/etc but ECM is what's going to limit your fueling unless you get a box that fulls it.
Gotcha. Well I’ll get one on the way so I can get it when I get the Qaud. Anyone wanna loan me 675$? Jk lol
Ordered two of them just in Case one breaks.
On 5/2/2018 at 6:22 AM, trreed said:
Yes. HX35 has a divided exhaust housing. And yes, there is no issues with running and undivided gasket on a divided setup like ours. When you put a divided gasket on an undivided housing is when you start asking for trouble.
On 5/5/2018 at 5:16 PM, Ed ke6bnl said:
I did recheck the boost gage and it is correct, mine will only develope a max of 28 psi, but I relocated every thing so it is easy to access and will be able to maybe cut some of the spring and do some tests, That does make sense, that it would have to bleed back or the check valve would keep it pressurized. thanks for the input.
Don't cut the spring. If you are looking for more boost, assuming you have enough fuel and don't have any boost leaks or other problems, if anything you need MORE spring, not less spring. You could add a shim. But honestly, if your tightened all the way, then there's a boost leak or you don't haven't enough fuel.
I'm glad that everyone is having good results with this, I was a little worried after posting that I would be the only one that liked it! Mine worked great until I snapped the input shaft on the 47RE. No plans to get the truck running again this year... I have a wedding to pay for. I won't be around here much for a while. The 2014 Hemi 1500 will get a little love... And the 2003 Jetta TDI will get just just enough love to keep moving. Can't complain with a 45mpg car that'll roast the tires I guess.
The j hook just holds the waste gate closed and the boost controller can be set to open the waste gate at a certain psi of your choice.
Though that takes some trial and error from what I have read here.
Edited by dripley
Mine never came from eBay and it says they no longer sell it. First time I've had something not show up legitimately
Same here, just wrote them another email last night. Good thing it was only a few bucks. First time they replied that they will send another since first one never showed up, well second one never showed up either no response, nothing I'm done buying from China sellers on eBay. Funny thing this was first time I even tried buying anything from China
I've had a bulb kit and radiators show up from China but both were junk
@rogerash0
did you order one and they said they no longer sell them and not charge you or give   your money back?
I went to their ebay site and they have them for sale.
Yeah I'm done with China garbage, unless it's from Harbor Freight where I can take it back or exchange it. Even then I only buy certain things there.
Don't be so quick to condemn. They'll pop up again under some other account in a week or so.  Just how it works.
I have an extra I’ll sell. 5$ is shipping.
