Bulletproof mods
Mods that I have that benefit my 2nd gen...
Gauges
 Fuel pressure with led light
Egt
Trans
Fuel system half inch, air dog set at 19 psi
Deep dish trans pan
For the future...
Latest mod to wiring (Not sure of name)
Trans rebuilt (this summer?)
Going to check/fix killer dowel pin
Pull out dent mom in law gave me.
Towing mirrors
What are your bulletproof mods?
  • Replies 49
  • Views 15k
    Oh... I can't resist...   Dripley even got a built-in trough for routing the chicken grease to the fuel tank. Biodiesel anyone?
  • Dripley forgot the chicken roticerie over his exhaust manifold. Even got a 'Chicken Done' gauge on the dash.
  • cajflynn
    cajflynn
    Because my 3rd gens all had injector problems.  I blew quite a few motors after an injector or two got stuck open.  My 4th gens have been far more reliable.
Gauges
Egt
Trans
Deep dish trans pan
For the future...
Towing mirrors
Fass 150 half in lines
2 stroke in fuel
Future mods:
Either Qaud Adrenaline Or Xzt.
Thats it! :lmao:
Edited by Marcus2000monster
gauges
 EGT
 boost
 fuel pressure
 tranny temp
AD lift pump w/1/2" lines. used relay to get pump power off ECM
BHAF
2 stroke. not a mod but it sure makes a difference. 224k on current VP
@W-T's ground and charging mod.
Power steering flush w/ magnefine in line filter
Just installed trans temp guage to see if I will benefit from fast coolers while towing this summer.
Would like to try an adjustable track bar
Definitely need to check into that ground
and charging mod.
2 cycle oil in the fuel for Injection pump life.
235/85 R16 tires for the front suspension life.
Exhaust brake for brake life.
Ground mod for the electrical and electronics performance.
AirDog / FASS for injection pump life.
ISSPro Gauges for warning protection.
I left off my EB. One of my favorite mods. I guess because it failed a while back and it seems Banks does not seem to want to sell me just the actuator. Want answer the emails I sent any way.
This was a simple mod for me and cost less than the stock tires but watch this...
35 to 37 inch tires. Now the list of upgrades that you should do to handle the larger tires.
Steering box brace to keep the stress off the output shaft from the larger tires.
Heavy duty T steering to upgrade from the factory Y steering.
Adjustable track bar if not upgrade to 3rd gen style track bar that is adjustable.
Long control arms to correct the geometry of the front axle after the lift /leveling kit to fit the tires.
Upgraded shocks and steering dampener help prevent death wobble common with most oversized tires.
Upgraded steering gear box (Blue Top or Redhead in slow ratio to reduce stress on the steering box)
3rd Gen brakes to stop all that rotational mass of the larger tires.
Axle gear change to get the final ratio corrected for oversized tires. (Final gear ratio 3.55 to 3.73 to the ground)
Upgrade the transmission (Automatics) to hold up to the added stress that oversized tires produce on the transmission.
Upgraded clutch (manual) same here might consider a dual disc to hold the torque demands.
So I made one change from 265/75 R16 to 235/85 R16 dropped the aluminum wheels 16x8 for factory 16x7 steel wheels and tires cost me much less but all the front suspension lasted MUCH longer.
185k OEM ball joints
340k OEM tie rod ends
150k miles OEM track bar, 180k miles on NAPA  track bar
340k Steering gear box. Upgrade to Blue Top because of rust issues.
180k OEM brakes
300k Rear caliper (rust issues)
Still running... 16 years later and 341k miles on the clock.
OEM Rotors
OEM Power Steering pump
OEM front Calipers
Never had a death wobble issue.
Just food to think on...
  • Popular Post
Dripley even got a built-in trough for routing the chicken grease to the fuel tank. Biodiesel anyone? :lmao2::lmao:
2 cycle oil in fuel 1:128
Magnifine in line power steering/hydro boost fluid filter
ECM protection with fuel pump relay (for backup lift pump)
Fuel Boss pump
Edge EZ
Mystery switch with brake pedal disengagement
Electrical system ground modification
BHAF with heat shield
4" exhaust
RV275 injectors
manual boost controller
fuel pressure, boost, transmission and exhaust temperature gauges
Everything you do to your truck that is not a stock (factory type) replacement or repair is a modification and will void the factory warranty.:nono:
The only things I've done;
       Trans Temp and fuel pressure gauges.
        Mag Hytech Trans pan..
       IBM's Mystery switch
       ECM housing battery ground.
       Timbo Apps.
       Vented fuel cap.
       Tank access plate in bed (not recommended).
       Greasable lower ball joints.
       Heavier PCM ground to firewall.
       Vulcan big line kit, draw straw and frame mounted lift pump / relay
       2 stroke in every tank.
Future mods
      W-T,s grounding mods.
Actually it is just one of those pop up things like you in the grocery store birds to let ya know they are done. Just reload after every chicken.
My truck and I like that bio blend. Runs even quieter than just the 2 stroke. Damn stuff getting expensive though so I don't run as much here lately.
But now when I stop for fuel, I just sell a few chickens to pay for it. Winner winner, chicken dinner.
Oh thats too good:lmao::lmao:
Oh yeah!! This is as much fun as screaming beavers and wood.:lmao2:
Edited by dripley
I became my own warranty station back in 2004 (51k miles) when I gave Dodge Dealer Tech the middle finger and refused to take the in-tank lift pump. Since then I've studied and made proper replacements to extend the life span of the truck. Which I would say I've done quite well. That's my big focus everything I do is to extended the lifespan of the truck. Cool factor is meaningless to me...
:lmao2::lmao:
Yeah I've got access to B5 over in Ontario, OR but heading for $3.50 a gallon is getting steep. I'm still capable of getting petroleum for $3.299 in Idaho.
Oh yeah!! This is as much fun as screaming bearers and wood.:lmao2:
It's about that time to break out the twins and the Big Tex go fire up the screaming beavers... Firewood pile is getting well rather small...
Seriously. Back on topic. It about being able to deal with the weak links and upgrade properly.
There is a lot of hype for some upgrades and mods which typically have no value for daily drivers. Like cold air intakes, updated intake horn, 4 or 5 inch exhaust. These mods for stock to mildly upgrade HP these don't have any effect on power or efficiency. I'm strictly talking daily driving no towing here.
Now everything beyond daily driving changes the requirements and what upgrades to do. This is why the signature line is handy for us to look at and make a proper suggestion based on what you plan on doing and typically task for the truck. Like currently I'm a majority highway runner now, low amount of towing but it will occur. Now there is other members here that have different goals and purpose for their trucks. Like some have welding equipment on the back adding weight. Some tow on a daily bases like @cajflynn did turning 1.3 million miles on a 2nd Gen truck. Still, it comes back to getting an understanding of the purpose of the truck and modifying to keep the wear of parts down.
Holy Cow... The million mile man visits the site for the first time in years!
14 minutes ago, cajflynn said:
Did someone say my name?
Yeah, I called you out as a tag...
Its a freakin ghost!!:ahhh:
Don't want to forget crankcase vent mod to keep radiator from plugging up!
Yep.  I'm a ghost.
I see the boats are still tailing ya. Somethings remain the same. Are you going for a million on the dually yet?
@cajflynn looks like you need to update your signature and tell us some stories about your current truck and how you keep it going. Mighty fine looking 4th gen truck... Time to share your secrets on the 4th gen.
