- Replies 69
- Views 13k
Jack Owen 22 posts
Mopar1973Man 10 posts
dripley 10 posts
Ben 6 posts
I think there was a miscommunication. Adding fuel won't drop EGTs, but adjusting the timing will. Honestly though, those are some really high EGTs and I'm not sure that a tuner only will fix your issu
The only thing that I have seen happen on our turbos is the bearings get worn out and the oil weeps in on the compressor side. Beyond that then I would build a boost test cap for the mouth of the turb
I think we all agree to a possible boost right gang?
put new DAP injectors in last summer. Have been fighting High EGTs and black smoke since. Didn't think +50 injectors would cause this much trouble. MAP 48 when pulling hard. Is there ANYTHING in the VP44 that can make it overfuel with no codes?
