put new DAP injectors in last summer. Have been fighting High EGTs and black smoke since. Didn't think +50 injectors would cause this much trouble. MAP 48 when pulling hard. Is  there ANYTHING in the VP44 that can make it overfuel with no codes?
  • Replies 69
  • Views 11k
  • Quadzilla Power
    Quadzilla Power
    I think there was a miscommunication. Adding fuel won't drop EGTs, but adjusting the timing will. Honestly though, those are some really high EGTs and I'm not sure that a tuner only will fix your issu
    The only thing that I have seen happen on our turbos is the bearings get worn out and the oil weeps in on the compressor side. Beyond that then I would build a boost test cap for the mouth of the turb
    I think we all agree to a possible boost right gang?
Really spit balling here but what if those were not 50's you got and are much bigger.
Since this started with the injector install maybe maybe DAP sent the wrong ones by mistake.
Can't thank everyone enough for the help. Let me review just a bit. This truck always ran EGTs on the high side when towing. Even with a new VP44 (thanks DAP) they still ran high. Without a trailer I could get then pretty high if I drove like a maniac. When I put the +50 injectors in is when I started to notice the smoke. I noticed the EGTs climbing the first time I pulled the trailer. Obviously I induced a couple of boost leaks when I put the big exhaust on. Before I fixed the boost leaks I could hit 1500 while driving very, very carefully. After boost leak fix the smoke is much less and I can hear the turbo spool faster. Without a trailer EGTs 900 or so 75mph. Pulling a trailer I am now seeing 1350, steady cruise 70 mph. It is MUCH better after the boost fix. I am beginning to think that time and mileage is beginning to take it's toll. My home brew fuel is known to leave more carbon deposits than regular fuel. I'm afraid that tuning the problem away doesn't fix the problem. I am going to try water injection to see what happens. The boost leak fix has made a big difference and I thank you guys for the advice.
Imo, there is still something wrong.
I just drove 2200 miles with a similar setup except larger injectors. No tuning, no boost fooler, and stuck wastegate. As long as vehicle load was 20% or lower my cruise egt's were 600 degrees give or take. I ran 1920 rpms whether speed limit was 65 or 70 per monitor.
Even with short hammers up to 90 mph and 30 lbs boost I never saw past 1000 degrees.
And I have no real visible smoke.
My old heavily fueled little truck never saw cruising egts like your are experiencing. I might of seen those on Mach 3 bomb runs but never cruising.
The "not 50hp injectors" is an interesting angle. May be realistic.
If you pressurized the system for the boost leak testing and just found those 2 then you need to start digging.
Something is off.
I wonder if your pyrometer crapped the bed. I went through 3 on my old truck but they each gave tell tale signs of freaking out randomly.
This was my usual view on my trip.  Don’t mind the fuel pressure.  I’m working on that.
Edited by Ben
My thought is that if he is the second owner, maybe the PO flashed a smarty or superchips tune on the ecm and neglected to mention that.
Maybe. Could explain the smoke if he's farmer footing the throttle.
I ran a Smarty from the MAD ECM days on. I never saw that hot with RV275's and 20k on the deck of a goose neck.
That was the beauty of mild setups. Plug n play/small injectors/stock charger. You could pull the world and not have your eyes glued to the pyrometer.
This was also well over a decade ago.
Now you have me thinking.
@Jack Owen if the truck is in neutral or park and you hammer the throttle do you blow black smoke?
The MAD ECM and Smarty would give a good cloud for me on an off idle snap.
Edited by Ben
Hmmmmmm....some evening testing. I secured my boost gauge next to my pyrometer and made some hard passes, no trailer. My egts hit 1100 before my boost gauge even moved. At 1400 I only had 10 psi. Could my turbo be crapping out???
Please explain what you did by securing your boost gauge next to your pyro.  Something is wrong with this whole deal.
Just my opinion, your charger is fine, Have you done  a manual man handling of the compressor side? No in and out play some lateral thunk thunk but no contact marks on the housing?
You have yourself an awesome dumpster fire to figure out. It just unfortunately keeps getting better.
How bad was the smoke when you did your test passes?
When you checked for boost leaks did you charge the system with air or did you just do a lookey loo and found some obvious ones.
Upon further review, your charger did crap the bed or you have a hellacious boost leak still.
I didn't think HX35's died unless seriously flogged.
Edited by Ben
Another idea. Have you checked your exhaust manifold for missing bolts or cracks?
I'm also curious of that statement.
As you'll see my boost and fuel pressure sensors are mount on the driver side fender.
iss-pro-fuel-pressure-sender.jpg.8786ebf
Boost gauge tap point right next to the MAP sensor is a 3/4" pipe plug. As you can see I bushed it down to 1/8" NPT for the sensor. The tubing runs all the way back to the sensor on the fender. I did this so I wouldn't damage the sensor working on the engine.
Image result for mopar1973man pyrometer
As for Pyrometer, it should be in the 4, 5, 6 port of the exhaust manifold.
I zip tied my boost gauge next to my pyrometer so I could watch them both and not die ...lol
Just got off the phone with Quadzilla and was told that a tuner wouldn't help my EGTs? WTF
  • Popular Post
I think there was a miscommunication. Adding fuel won't drop EGTs, but adjusting the timing will. Honestly though, those are some really high EGTs and I'm not sure that a tuner only will fix your issues.
The Adrenaline will adjust the timing how you want it over the RPM ranges. You can see a drop in EGTs but at 1350* cruising, there is definitely something else going on there that should be addressed.
One thing the Adrenaline will also do is add a second EGT probe so that you can verify that your current one is accurate. It would be a shame to chase a problem that isn't real.
I wouldn't be buying an ADR to try and fix your egt issues.  You have other issues going on and the ADR won't solve them.
I have agree with Me on this. You have another issue causing the high temps or temp readings.
If the issue started after installing the injectors I would be looking at your injectors as the issue.  have them tested see what they come back as.
