P1291 With grid heats disconnected
- Replies 13
- Views 3.1k
Mopar1973Man 5 posts
dripley 2 posts
sooxies 2 posts
SilverMoose 1 post
Talk to @IBMobile he got an idea on how to fool the grid heaters without throwing a code.
I've hooked back up the grid heaters on my truck. Now that I've tested my alternator and done the @W-T ground wire mod. I'm going to monitor this winter and see if the alternator holds up better or no
I've been starting the engine with the grid heaters disconnected for 6 weeks with morning temps ranging from 28°-55°F with just a little white smoke and a loping idle for about 30 seconds. This afternoon, after my wife drove it this morning, the check engine light was on. I scanned the system with an OBD code reader and fond this, P1291 No temp rise from intake heaters.
Monitor & Set Conditions
Temperature rise from intake air heaters is monitored for first 15 seconds of engine operation. DTC may be stored if initial Intake Air Temperature (IAT) sensor reading is 0-66°F (-17.8 to 18.8°C), Battery Temperature Sensor (BTS) and IAT sensor are within 10°F of each other, time between end of preheat and engine run state is less than 30 seconds, engine is cranked for less than 5 seconds before engine starts, preheat is completed before engine starts, post-heat is active and no IAT sensor or intake air heater relay DTCs exist.
This shows that a code, under the right temp conditions, can still be set with the ECM still closing the rely but the main power to the grids disconnected from the battery.
