- Replies 42
- Views 7.5k
Dustin24v 13 posts
Mopar1973Man 9 posts
Me78569 8 posts
Evan 4 posts
In short and repeat as many times as necessary
That's a pretty accurate description ^
If you want 500-550 hp then I would choose the 62/68/12 VP trucks do much better with a 12cm exhaust rather than 14.
Back again for my second post.
So the problem is when I'm getting on the freeway if I push the throttle any more than 50% while going from 35 to get to 75. When the TC locks the truck will surge and the turbo will bark as the boost jumps from the 32psi I have the adjustable boost set at up to 45 psi. Don't know how it gets past the 32 i set it for but it does.
After it locks with same throttle position after I get past 60-65 it stops and will not do it again unless I do the above scenario.
I think I already know what it is, which is that I'm still running a hx35 on a built transmission and triple disk. And with all the go fast parts the turbo over spins?
I should mention that I am not pouring out soot only a light haze when I do the above.(trying to keep it short sorry)
I have a lot of mods... ones that are relative. New Bosch VP44 from thoroughbread about 2k on it. New timbo app 1k. Bhaf. 7x.010 SAC sticks. Edgecomp smarty stack. Goerend tc and vb. And bd stage 3 rebuild.
Any thoughts of I'm correct on the stock turbo being the issue. Any ideas on how to keep the boost at 32?
Bigger problems? Hunting season coming up so I'm on a tight budget... haha priorities.
Thanks in advance for your replies.
