- Replies 30
- Views 7.3k
Mopar1973Man 9 posts
dripley 4 posts
Dieselfuture 3 posts
Dmaney 3 posts
Popular Days
Maybe you ought to put some Krispy Kreme donuts on there. The glaze will give you good traction on something.
While the skinny part does not phase me the diameter does. I hope they work well for you. I am still hung on my 265's.
With your current injectors and tuning, a 62/68/12 would be a good fit. I have seen that setup (with slightly different tuning) make 502/1214 on a dyno a 7000' elevation. Remember, boost isn't the on
Where is the low power?
I've been pondering this.
Turbo upgrade?
Diff gears?
ECM mod?
You get to a point when all forms and info get so jumbled you forgot what you are looking for.
I don't tow much, some, but not much. I want that tire burning diesel action when I feel the need to use it.
I can get about 35 lbs of boost with my setup, which is good, egts climb to the 1500s at Wot( rarely at Wot) . Little worried about that. From what I read my Hx35w (54/60/12) is a good turbo, but a 60/60/12 or 62/68/12 would spool faster. But would that rip the tires loose? If so what is the right turbo internal upgrade?
I thought about changing diff gears to 4.11 for low end power with my 285s but my current 3.55 seems to be where I need to be.. I think.
I've also heard talk about a Mad catcher ECM mod ripping off the line but don't know how it plays with quadzilla.
Once I'm rolling, it's on, but from a dead stop what's the magic ingredient to rip loose? What am I missing?
