- Replies 25
- Views 3.3k
LegendaryKing 6 posts
dripley 5 posts
Dieselfuture 4 posts
Mopar1973Man 3 posts
Popular Days
Truck is stock for now. I'm researching the most reliable way to meet my 400-500 hp goal and I'm conservative and tend to over build for reliability. This comes from my time building racecars. Ligh
Diesel auto power. They are a vendor here. You can also talk with SB direct about your also.
Southbend's part # HYDX1-50 has an adjustable pedal feature. This is important as the OEM and other aftermarket non-adjustable pedal clutch hydraulics will likely frustrate you because they probably
The clutch is slipping so it's time to upgrade. It's so bad I hope I make it home.
Which online store has good customer service and sells southbend clutches?
