Power Steering fluid swap
- Replies 15
- Views 8.7k
Mopar1973Man 2 posts
dripley 2 posts
NIsaacs 2 posts
Bar GN 1 post
Popular Days
Don't do it. It will cause seal failure. Our system are designed for power steering fluid. 3rd gens are a Ford steering box and requires ATF.
I vacuum out the ps fluid from the reservoir and replace with new each time I do an oil and filter change. I also draw out as much coolant from the radiator and replace with new every other oil chang
I know most of us take such warnings with a grain of salt but...this is right out of the 2nd gen FSM. CAUTION: Use only MOPAR power steering fluid or equivalent. Do not use automatic tra
My 99 has the typical power steering growl. I had a 98.5 that did the same thing and I swapped the fluid with ATF+4. I wanted your opinion on it and if there was an easier way to fluid swap. I vacuumed the fluid from the reservoir, filled with ATF, ran it, then repeated the process until I thought I had mostly new fluid. Ran it for a couple of years with no problem and was noise free. Thanks for amy input.
