Oil Pressure and oil type
- Replies 21
- Views 5.7k
Mopar1973Man 4 posts
Marcus2000monster 4 posts
SavageTusk 3 posts
NIsaacs 3 posts
I would check with mechanical gauge pronto
Synthetic oil are not required. Most of the big milestone guys are strictly petroleum oils. I suggest you get the oil pressure tested.
Like an old TDR article... Designed at the time of the release of CJ-4 oils. TDR57_Oil.pdf Then if you ask @cajflynn about oil changes on his 1.3 MILLION mile truck 2001 Dodge he was
I know the oil pressure sending units and readout are not the best in the 99 dodge rams. Mine is fine when running but drops to 0 at idle. The engine sounds perfect so I assume it's the sensor / sending unit.
My question, does using fully synthetic affect this at all? I wouldn't think so but thought I'd ask.
Edited by SavageTusk
