Fuel Tank Module Check Valve
- Replies 34
- Views 7.5k
Greenlee 12 posts
dripley 9 posts
Mopar1973Man 4 posts
IBMobile 2 posts
I'll do a sump again when I can control road debris on the roads. Couple bulk head fittings drilled into top of module and push on fittings for me. PVC pipe from ace hardware to suck fr
Smart ***!!
Perosnally, I would get out of the stock sender. Install a draw straw of some sort. The stock in-tank pump is restrictive from the get-go. All the factory plumbing is too small measuring out at 6mm ID
I'm having fuel pressure issues on the 1999 24v. The pressure drops and you have to readjust the Raptor lift pump to correct it. When I bought this truck the VP44 went out in the first 2 weeks. I removed the electric lift pump from the tank but never removed the check valve that is on the suction line side about 3/4s of the way down the module. I watched a YouTube video explaining that when you eliminate the lift pump in the tank you need to make modifications. The check valve is part of it and should be removed. Has anyone else ran into this or has had fuel pressure dropping and it has to be adjusted back up again? Any opinions on a G&R sump for the bottom of the tank and leaving the fuel module alone? Would I have to change out a fitting on the return side of the Tee to fit a 1/2" hose like the AN-8 fitting on the G&R sump? I can't crawl under the truck and look but I want to be able to pass it on to who ever is helping me work on it. Thank you all for any advice.
