Another Rectifier/Diodes Failure
- Replies 30
- Views 6.1k
Mopar1973Man 6 posts
dripley 6 posts
sooxies 5 posts
Stormin08 5 posts
My truck was bought and has stayed in San Diego County, except for trips. The grid heaters come on during the cold mornings here and it also has a block heater which I've never used.
Bosch alternators are not easy to rebuild from what I understand you have to unsolder each diode one at a time and replace them. Where the Denso alternator is a package like what you see above.
It doesn't sound quite right. Perhaps your Denso is off of a different car or truck. You might do better to go get the correct Denso for our trucks and keep the rebuild parts for the future.
Finally got around to disassembling my old alternator. I believe this is the factory original one. Unfortunately I stripped out 2 of the 4 screw heads holding the diodes in!
Any tips for stripped screws?
Anyways,
@Mopar1973Man The diodes you sell...do they fit in all Denso alternators found on 94-02 trucks? I have a 98.5, which from the looks of it, is the same as a 12 valve alternator. It doesn't have that plug on the back (see photo from FSM).
