2 stroke oil and fuel pressure
- Replies 21
- Views 4.1k
Mopar1973Man 7 posts
Collinst15 5 posts
Dieselfuture 3 posts
Bullet 2 posts
That's a very small difference that could be attributed to alot of different things...fuel filter getting a little dirty, air conditioning on, fuel in the tank is cooler, air in your fuel pressure gau
Grid heaters alone can pull fuel pressure down.
4 things that will kill a VP44... 1. Low fuel pressure below 14 PSI. 14 to 20 PSI is optimal! 2. Poor fuel filtration. Stock is 10um but 3 um is preferred and double stacking is bette
Good morning everyone,
Yesterday I started using 2 stroke oil at fill up. I have a reman vp44 from T-bred with 1000 miles and been reading 2 stroke oil is the way to go for pump longevity. After I filled up I noticed my FP was at 14.5ish lbs compared to the 15lbs it was at before adding the 2 stroke oil. Is this normal? Has anyone else seen this? I have an Airdog 4g lift pump so I'll just increase the pressure tomorrow but thought it was odd my fp would drop.
Tim
