Buying a rolled over truck.
I’m looking at buying a 99 24 valve that has been rolled over to either part out or fix up. It has 285k runs well drives well I’m not sure if it’s a 5 or 6 speed yet. Owner claims it gets 21MPG on hwy. Also says he still drives the truck occasionally. He wants 4500$. What do you guys think? Link below for pics. https://spokane.craigslist.org/pts/d/reduced-1999-dodgex4-quad-cab/6754872442.html
  • Replies 51
  • Views 7.4k
  • I hear "rebuilt" I see 18yr old kid slapping in bearings, rings, head gasket and painting the block.  I bought My 01 w/68k pulled weight until the 53 block cracked at 453k, got new block from Freightl
  • A match book was a good tool. You could gap and clean up a set of points. Very versatile and cheap too.
  • I would trust a running engine over a "rebuilt" personally,maybe because I've seen others peoples work. that might just be me though. Most rebuilds don't come complete, Long Blocks etc, lots of extra
You could but a vintage truck cab on it
How bout a '41 chevy
$4500 for a truck that was rolled???
looking at the pictures I would give it %50 of that max assuming the driveline was in good shape.
Yes. 50 more or less than asking pxrice?
99 has the POS roll over safety belt lock module under the front seat... I wonder if it worked?
 He means $2000
Soon you'll have a pretty good supply of used 2nd gen parts if you keep buying these.
It depends on what you plan doing with it.  Is there something in that truck that you want or are you wanting to part it out and hope to recoup your money?
 He means $2000
A good 24V engine goes for around 2K with those kind of miles,plenty left over to turn a profit.
If I am looking to buy parts to make money I normally use the %50 rule of thumb to cover time and costs that are not directly evident.
IE if I buy it for $1000 I need to make $2000 to make it worth it.
I dont see making $9000 that vehicle.   I see ~3-4k in parts, ~$500 on scrap and ~80 hours of trying to part stuff out.
Edited by Me78569
1 hour ago, Marcus2000monster said:
Either part out or fix up body.
I bought a 93 Jeep Cherokee 250K for and no interior for $200, parted it out by the time I sold the body to some guy I made $1200 profit. If you can pull the parts and don't have to worry about it costing $45 to ship a $25 part I don't think you'll have any problem turning a buck, But get it as cheap as you can.
Edited by Blueox01
Might not double his money, but hard to find a good used 24V with those miles under 4K, not to say they can't be found. Still have Trans, Trans case, Diff,Leather interior, Dash, some body parts. I think I would leave in Truck till sold so buyer could hear run , De-grease and power wash engine. I sure I could turn a decent profit, depends on how fast a person needs to recoup the initial investment https://www.mylittlesalesman.com/cummins-59l-engines-for-sale-i4c235f575m166280,
33 minutes ago, Mopar1973Man said:
Way too many 2nd Gen out that are totally molested. Just look at FB groups...
I don't do Facespace  What's molested mean? Cannibalized?
Edited by Blueox01
16 minutes ago, Blueox01 said:
I don't do Facespace  What's molested?
%85 of the 2nd gens on the road today.
I simply cannot value a 24v with 300,000 miles at 4k.   There is a reman 24v on craigslist locally for 4500 that is "rebuilt"  Considering the time it takes to part a vehicle you need to consider time into the entire thing,  if you spend 80 hours tearing stuff apart / talking to people / post on craigslsit / meeting people / shipping then $1000 profit is nothing.  you can make more working at hobby lobby.
it takes a lot of time and effort to part a vehicle.  Been there done that, it's not profitable unless you get your vehicle at pennies on the dollar.
I would trust a running engine over a "rebuilt" personally,maybe because I've seen others peoples work. that might just be me though. Most rebuilds don't come complete, Long Blocks etc, lots of extra goodies on a pulled motor. But that's just me.
for me I see 300,000 miles and I automatically think "it will need to be rebuilt"
456k on mine with just normal care. But who knows what a PO considers normal. I am by no means a @Mopar1973Man. Of course I do have a HG replacement coming up. :think: My first in many many years.
I hear "rebuilt" I see 18yr old kid slapping in bearings, rings, head gasket and painting the block.  I bought My 01 w/68k pulled weight until the 53 block cracked at 453k, got new block from Freightliner, had crank checked, head done, since it was already off , went another 400k, till I burned a hole in #6, Crank is still standard, #6 sleeved, Head needed a few valve guides and a few valves replaced, surfaced. Can turn the crank by hand after all the mains torqued.Hey but who's know might start knocking at start up or leak like a sieve going down the road. But hey it's looks purdy. I guess to each his own.
Edited by Blueox01
Throw @cajflynn in the pile then 1.3 million miles never rebuilt.
That the hauler w/ the brown 2500 2wd?
Edited by Blueox01
