Oil Pressure gauge
Okay getting close to wanting to throw fuel in my tank and see if my engine even runs, but I want to make I didn't miss (or screw up) anything. So It's been 8 yrs since it's run some my memory it a little foggy, anyway when I turn key to on Oil pressure gauge goes up to 40psi, Tap starter it goes back down, this correct? Obviously I don't know what it will when actually started, Sure I'll have oil pressure just don't want to backtrack any on any wiring.
  • Replies 25
  • Views 9.7k
  • Marcus2000monster
    Marcus2000monster
    Can’t help you they’re but get videos of startup and Post em up!
  • Mine does not. But I have the single wire switch and not the sensor. I have heard of that going to 40 at key on mentioned here recently by someone.
  • 01cummins4ever
    01cummins4ever
    My oil pressure gauge doesn’t go up with key on either, but maybe some are wired different . Thier is acually a slight delay on start up which I believe is normal for these trucks. I would hook u
I would hook up a mechanical gauge on the engine at first start up just to verify the  factory gauge.  just for peace of mind
Mine sensor did the same thing,  it was a result of a bad sensor.  proper operation should mirror actual oil pressure if you have a pressure sensor and not the switch update.
I checked the leads to the sensor, I have 5v at the orange wire and continuity to ground at the bk/lb blue wire, so I believe that's right, anyway to test the sensor before I spend the $$$ on a new one?
Switch update?
you can probe the output from the sensor to the ecm
Some trucks got a fuel pressure switch uipdate and a dummy gauge, some got true oil pressure sensors.
the pressure switch is a 2 wire setup the sensor is a 3 wire setup if I remember right.
My switch is a 1 wire set up as is the spare harness I have.
Well if the electronics is acting up I would screw in a mechanical gauge to verify that you in fact have oil pressure.  You have too much invested in that motor to not!!!!
My factory electronic gauge is still acting up but I'm thinking Ground on the 5v system.  I'm running a second Oil pressure gauge.
Michael
Okay, I rechecked the connector I have 5v with key on/ too OR wire and .044 ohms at BK/LB wire, nothing at sensor wire. With key Off I have continuity to Gr with the BK/LB, nothing on other two wires, I did ohms test sensor it has 1.16 omhs between terminals BK/LB and sensor wire terminal
Michael
Well It turns out that my Oil Pressure and MAP Sensors was the defective 5 volt source.  And the replacement sensors are not working.  I replaced the aftermarket MAP Sensor, with the old OEM and it started to work again.  I just bought a new Oil Pressure sensor from a member here and will install it next week.  I had 4.98 volts from Red to Black wire on both MAP and Oil Pressure plug.
Didn't ohm the sensor.  Sorry
I have a second gauge screwed in at the filter second plug.
Michael
Edited by int3man
Michael
I'm must be checking it wrong, I'm going between Batt Gr on both tests
15 hours ago, Mopar1973Man said:
If you have a 3 pin sensor then you have to use the ECM sensor ground in that plug.
If you have a 1 pin like I do then you use the battery ground.
Ok, I have 5v between OR wire power & BK/LB wire Sensor ground, I also get 4.6v between Power OR wire & Sensor GY/BK wire, that right? Looking at Wiring diagram 8W-30-33 2001 Manual
Well I've got an aftermarket sensor, I'll go to Freightliner or Cummins tommorow and see what they get for one.
Michael
Just got back from a WOT test and got up to 20# of boost.  V2 Tune Works Great!!  No Smoke, only in O.D. and laying on the throttle. YEA Baby, So much fun when it works!!  Oil pressure sending unit next week and then I can loose that pesky check gauges light.  I wish that I had not thrown that original Oil pressure sending unit away.  It was probably still good.  Oh well lesson learned.
Michael
Get that boost pressure up and it most likely wont smoke in OD. I would that would be capable, but I am not a turbo man by any means.
Big Turbo and Big injectors take time to get the Boost up.  The V2 really helps with it's ability to tie your less that factory fuel level to Boost Level!
Michael
Michael
Ya, you beat to that oil pressure sensor, I was going to get it today,early bird gets the worm.
Edited by Blueox01
I was an idiot and threw the old sensor away.  I would bet that the old oil pressure sensor was still good!!  My MAP Sensor was!
Michael
Michael
Ya I'm gonna dig through all my Cummins parts that are scattered all over, see if for some reason I kept my old one, can't remember why I replaced it, but I am a pack rat, maybe I have one. Somewhere.
Michael
Did the OEM oil pressure Sensor solve your problem?
