- Replies 25
- Views 11.3k
Can’t help you they’re but get videos of startup and Post em up!
Mine does not. But I have the single wire switch and not the sensor. I have heard of that going to 40 at key on mentioned here recently by someone.
My oil pressure gauge doesn’t go up with key on either, but maybe some are wired different . Thier is acually a slight delay on start up which I believe is normal for these trucks. I would hook u
Okay getting close to wanting to throw fuel in my tank and see if my engine even runs, but I want to make I didn't miss (or screw up) anything. So It's been 8 yrs since it's run some my memory it a little foggy, anyway when I turn key to on Oil pressure gauge goes up to 40psi, Tap starter it goes back down, this correct? Obviously I don't know what it will when actually started, Sure I'll have oil pressure just don't want to backtrack any on any wiring.
