- Replies 14
- Views 5.1k
Winesalot 4 posts
KATOOM 2 posts
Me78569 1 post
2000Ram2500 1 post
Reading through this thread, I do not see any information describing your truck, so a lot has to be assumed. On my truck, the CAD unit (center axle disconnect) has to be actuated to turn
Check the vacuum operated collar on the front passenger axle.
You could have a vacuum line issue, vacuum motor issue, shift fork or collar issue.
Yesterday I was trying to pull my loaded trailer out of a snow covered driveway. I spun the tires in 2wd so I moved the transfer case shift lever from 2H to 4H but the front wheels did not spin on the snow while the rears were spinning. I shifted to 4L and same thing. I have no knowledge on these truck as far as the 4wd system. Any thoughts or hints on what might have happened and how I should proceed from here?
