P0230 after new FASS
- Replies 25
- Views 18.9k
Nutter 8 posts
pepsi71ocean 6 posts
IBMobile 6 posts
Stanley 1 post
1.These people are looking at there bottom line. Customer support takes time and time is money. The person giving support has to be trained in all the products as well as what the prducts are going
The ECM does not see the lift pump. Following FASS instructions could cause injury or death. If you are in an accident and unable to turn off the ignition switch fuel will continue t
Those installation instructions are pretty generic; hot and ground at the battery with an ignition switch trigger. Maybe some person in the office trying to justify their existence by releasing new d
I've been reading up on every topic remotely close to the VP44 and fuel system for the last month. Lost my lift pump and sender unit same time which apparently blew my VP. So...100% stock 2001 6-speed...buy a new VP and decide on a FASS Titanium95. I read all the reviews but frankly the horse trailers and 5th wheels aren't a problem in these desert mountains (digression).
Have FSM, did install last weekend of both. Removed old filter canister and bracket (no going back, I shaved the bolts to match the others with no bracket) and removed old pump. Fuel line is just hanging. Taped and sealed each of the three connectors, then taped them together, then zip tied to the ECM harness.
FASS is battery and ignition fuze, so in my head, after reading all W-T and Moparman posts, I'm thinking my current lift pump has ZERO to do with the ECM. WTF? I popped a p0230 during bleeding. Ok...maybe a hold over, so I clear codes. It's late, it goes away, I shut the old lady down.
Start up in the morning and code comes back. Eff me. Maybe I didn't clear properly, do the drive to reset over a couple of days but...that night after work and multiple trips trying to get it to reset, CEL goes off. Sweet!
Nope. First start in the morning CEL stays on before Wait to Start goes off. Eff me. Start reading more from you guys about loose grounds...can't find any. Stop in to Auto zone to talk to local genius and make sure my code clear was legit, start it up for him and no CEL.
SERIOUSLY? Any help here would help me sleep this weekend while I'm out of town with this same truck after my code shows up again at 7am.
Edit: I checked the ohm tests mentioned in other posts before this fiasco with just the lift pump...but not after the repairs.
Edited by Nutter
Additional info
