- Replies 13
- Views 2.4k
Mopar1973Man 4 posts
mountaindan 4 posts
Dieselfuture 2 posts
JAG1 1 post
Popular Days
I just replaced the seals on the return and the " T" ,. replaced fuel lines from the tank to the VP. Also relocated The pump to the frame. It is working great now #2 injector was still leaking a lit
you loose prime and all the fuel drains back to the tank if you have an air leak in the return line. Kinda like holding the tip of your finger on a straw while in a glass of water and removing the
Good explanation of the issue. When the air leak occurs its the pressure side that let's go and returns to the tank. The return rail typically drains out anyways but there is no way for air to enter a
What does the"O" rings on the crossover tubes seal? Do they seal oil or fuel?
