- Replies 16
- Views 18.5k
Mopar1973Man 4 posts
Dieselfuture 3 posts
Ben 3 posts
Stanley 3 posts
Here is the installed test port. Eta- just installed new spring and ball. I’ll be damned, it worked. 18lbs.
The return line fitting on the pump. Remove the fitting and behind it should be a spring and check ball. Now there are a few things to do. The spring needs to be bent in a manner that the tail of the
See what happens. Right when feel special, a concrete block falls out of the sky and puts a knob on your noggin.
I have seen it before some where but cant find it anywhere... HA
Short and sweet:
Where can I get a shim or make one to increase my psi on my fass 200 titanium. Heard of guys shimming with washers, but id like to move from a consistent 14-15 psi to 20 psi for my bigger IP...
