Vibration after Southbend Dual Disc Clutch installed
- Replies 62
- Views 16.1k
LegendaryKing 18 posts
Mopar1973Man 16 posts
dripley 7 posts
CUMMINSDIESELPWR 6 posts
Update: I still do not have the truck back. Report from Trusted Installer: Transmission still isn't right. It comes out of gear when you come off throttle and back on throttle. Transmissi
Where to start? The performance shop that installed the clutch did not have availability to check the install and said it was fine/normal operation. Very acceptable right? They are now o
Wow. I dontthink I could have screwed it up up that even 2 cases of beer in the cooler.
So I just had a Southbend Dual Disc Clutch installed in my NV5600 truck and the whole truck shakes. If you press the clutch pedal in the shaking stops. Once the truck warms up it shakes less. It feels like the truck is running on 5 cyl. What is going on? Did the shop install the clutch wrong? Is this normal?
