Sport Headlight Conversion Kit and Raffle
- Replies 46
- Views 8k
Tractorman 8 posts
Dieselfuture 6 posts
Bullet 6 posts
JAG1 5 posts
The reason most anti-theft systems disable the starting system is after the engine is started the starter is just along for the ride. If the fuel or ignition system has a disable switch and the engin
The opening for the headlight housing in 2001 truck should be large enough to accommodate a sport headlight housing without any modifications. If you haven't done so already, be sure to relay the new
I dont see why a Board member can't buy a ticket, the process for picking is %100 programmical.
I was wondering if a board member can buy a raffle ticket?
Also my work truck has horrible bad headlights. So bad, I ran over a big chicken in the road
Chicken soup.
Anyhow is this conversion kit an easy kit or do you have to work at it a bit to make it fit? If I can't do the raffle I will go buy one. Thank you.
