- Replies 22
- Views 4.3k
Mopar1973Man 6 posts
Dieselfuture 4 posts
AH64ID 3 posts
01cummins4ever 3 posts
Popular Days
Fuel doesn't have to fully gel to stop flow at the filter, as you saw with all those solid objects in there. Typically the first unheated filter inline is where the fuel will gel if the f
I am not sure that filter location is to blame for gelling, but rather improperly treated fuel. Injection pump fuel temp won't keep filters from gelling. It doesn't surprise
I would think that the other truck had pourley maintained fuel filter, or even running to fine of a filter. even water in the tank can have the same effect on clogging a filter that gelling does in co
With this negative 30 bs diesel doesn't like to stay liquid anymore
