- Replies 27
- Views 5.5k
I'm sorry no one answered sooner. Yes there is a better solution to what you are doing. I think I'm correct in saying that the anti-gel solution dumped in the fuel is lowering the lubricit
Are you using something like this? https://www.genosgarage.com/product/na-33007-inlinefuelfilter/fuel-filters If you are I would guess that is your problem. As far as wind chill having an affect
Ding ding ding!!!! It's an apparent effect on living tissue.
So I have had a problem this winter with a freezing fuel filter. I put it in when I installed after market lift pump. The filter is a small plastic type with a metal mesh screen ( required by the lift pump manufacturer to have a valid warranty). Its located next to the starter between it and the frame rail. Never had problems before this winter. To solve the problem I have had to double the amount of anti gel as I have normally used and add # 1 diesel to keep it from freezing and stalling .
Is there a different solution to this issue other than installing a heated fuel filter on the frame rail ?
Thanks in advance
JOHN
