- Replies 13
- Views 2.9k
015point9 3 posts
Dieselfuture 2 posts
rambo 2 posts
NIsaacs 1 post
Popular Days
I lost one of the plug bolts coming down the siskiyous towing wives trailer. I burned a hole about the size of a silver dollar what's above the hole. Scared me and my wife half a death as it made a
I agree. My temps are over 500 at idle when I use it for warm up. On a 5 mile 6% down grade, heavy load and high RPM mine is more like 800.
Since 05 or 06. Always worked well other than that bolt falling out as mentioned above. But for other reasons I am never going to buy any BD product again.
My first turbo diesel a 01 3500 w some modes to pull better. A Smarty programmer, S362 turbo, stk head bolts, stk injectors, 5' straight pipe exhaust axle dump, 3 piece exspantion joint exhaust manifold, BD exhaust brake. My questions are, when applying the exhaust brake exh. pressure will increase from flow restrictions causing heat to build up raising pressure even more, can the clamping force of stk exh. hardware or head bolts fail or stretch an loosen causing gaskets to move an leak? If possible can these press. be monitored and managed?
