Dreaded White smoke.
- Replies 28
- Views 20.5k
Dieselfuture 7 posts
903Dodge 6 posts
Nicarlov 6 posts
Mopar1973Man 4 posts
White or bluish-grey? I agree it’s probably turbo seals, but the startup oil smoke sounds more like valve guides. Most likely on the exhaust side, but is pull the compressor o
When my turbo blew up the road behind me was all white for about a 1/2 mile.
If you get bored you can skim through my threads
I have white smoke when I start up. Smells like oil. Doesn’t matter the outside temp. Also when I accelerate (under load) there a haze of white smoke but clears up when I get to speed. Doesn’t matter if the Quad is on or off.
It did this with the old 75hp injectors and still with the new 150hp injectors. No loss of coolant or loss of power. The head gasket and ARP head-studs where replaced last year. Had the head rebuilt while it was off.
Any suggestions?
Appreciate the help.
