- Replies 34
- Views 9.7k
Miami Outlaw Diesel 11 posts
Mopar1973Man 7 posts
Me78569 6 posts
trreed 3 posts
It took me 3 years to get the Quadzilla all figured out. I'm still learning new tricks all the time. Start easy. Set it for level 3 and work with only the timing and the CANBus fuel.
62/73.4 will fit in your T4 .91 and would be less expensive as you would not need a turbine housing (save about $160, or $210 if its hx40 cut) Would be better to do a 62/68/.83 T4 for the
brothers. i have a 2002 Dodge Ram 3500, 5.9 Cummins, twin turbo (66/75), cam, fire ring head, 300hp injectors, hot rod pump, methane, suncoast to put it down, and a Quadzilla V2. I am getting way too much smoke and way too much lag. it sucks. I live in Miami and can't find a soul to tune my truck. so I am reaching out here, hoping to find someone willing to point me in the right direction in setting up my Quadzilla. Also, sadly, if i set the level above 1 (say 2, 3, 4,5,, or 6), she bogs down. PLEASE HELP. FUUUDGE
